Ceiling mount for sanyo plv z4
Discussion in 'Projectors, Screens & Video Processors' started by simon69, Mar 12, 2006.
  1. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    Anyone help me out on this?
  2. kesey
    kesey
    Oct 14, 2005
    +5
    Do you want one of us to install a ceiling mount for you or what?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  4. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    Thanks for your replys, if possible I would like a ceiling mount that does not invert the pj.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Why?
  6. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    The fan noise is supossed to be an issue
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    in that case you need a unicol cradle mount i dont see why the orientation would make such a difference (or could try the Sanyo wall mount with mirror)
  8. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    Thanks I will look into the cradle mount.
    There are 1 or 2 posts about the fans having to work harder (and noiser) when the Z4 is inverted to disipate the heat.
    If someone could comment about this.....
  9. EdR
    EdR
    Sep 17, 2003
    50
    It definately does make more noise when inverted - makes a very big difference to the overall noise level IMHO, so much so that I ditched my Vogel ceiling mount to reduce the noise level.
    If you want to experiment for yourself, simply set it to ceiling mode in the orientation menu and listen to the fans kicking in after a few seconds, then put it back to normal and decide if it matters to you...:smashin:
