ceiling mount for hs2
Discussion in 'Projectors, Screens & Video Processors' started by handyandy, Aug 29, 2003.
  1. handyandy
    handyandy
    Hi all. I have just brought my first projector, and have found this place to be a gold mine of information. It is a HS2 and for the money I am really pleased with it. I would really like to ceiling mount it and I am wondering if anybody has any information on how to do this. Where can I get a bracket for it and how much are they?
    If anybody has ceiling mounted their hs2 I would be really grateful of any tips you can give me.
    Cheers!
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Hi, and welcome to the Forums.
    If you check out the FAQ at the top of the list of posts, you'll find a couple of links to making your own ceiling mount - easy to do if you're reasonable handy. Lots of other info there too.
    If you'd rather have a readymade mount, you could try LMP or Nexnix, both are forum sponsors, and hold excellent reputations with forum members for customer service.
    All the best,
    Sean G.
  3. handyandy
    handyandy
    Thanks Sean
  4. FazerThou
    FazerThou
    Aug 23, 2003
    1,809
    Bath
    +138
