Ceiling lights with remote control
Discussion in 'Home Cinema Buying & Building' started by wizardmax, Feb 23, 2005.
  1. wizardmax
    wizardmax
    I am trying to achieve the following: I would like to be able to turn the ceiling lights on and off by IR or RF remote control (with out dimming) by installing a wire-in IR or RF receiver in the ceiling light box. I'd rather not go with X-10. Does anyone know where I can find what I am looking for?
  2. andybed
    andybed
    Dec 11, 2002
    47
    West Midlands
    Don't know of any system which controls without dimming, but Rako (RF)dimmers can I think be set to 'fade' up to full brightness and can be controlled via switch or remote. Not cheap though - £100 (Remote control), £93 per lighting circuit (RF receiver). Also easy to install.
  3. johndickinson
    johndickinson
    Jan 9, 2003
    375
    28
    +28
    I replaced my wall switch with a RF from John Lewis. If you hold down the button on the remote it dims, however if you press the button the lights come on fully. The same applies in reverse when turning the lights off.
    Hope that helps
    John
  4. SMooV
    SMooV
    Mar 2, 2005
    23
    4
    Tayside
    Have never used one myself, but the link below could be an option. If you do get one, then let us know what its like, as I could be persuaded (dependent on er'indoors).
    Infra-Red Remote Control Light Switch
