Ceiling Bracket for Sanyo PLV-30
Discussion in 'Projectors, Screens & Video Processors' started by peopleIknow, Jun 5, 2001.
  1. peopleIknow
    peopleIknow
    Aug 22, 2000
    181
    I have been informed that the official ceiling bracket for the Sanyo will cost around £350.
    Does anybody know of any cheaper alternatives.
    Alternatively, if some one as one could the publish the spec's so that I could see if it would be possible to have something similar made up ?[
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    The popular choice right now is the Unicol Gyrolok bracket.
    It is possibly the most versatile design you'll ever find since it can work as a ceiling or wall bracket and can even cope with angled ceilings in loft conversions. Gyrolok sells for about £200.
    Alternatively you could go the DIY route. The PLV30 projector has 3 brass threaded inserts moulded into its base. Put up a shelf, drill through some holes in the right place and use some small bolts to secure.
    Regards
  3. Weiman
    Weiman
    Feb 25, 2001
    25
    Gothenburg, Sweden
    I built a wall bracket for the PLV-30 by doing exactly that. Worked out really well. Use M4 bolts.
