cdwow vouchers- some advice pls
E
Ewan
Hi!
Found some cdwow vouchers on these forums for getting £1.50 of any dvds. Thinking about using one £1.50 to buy "Bad boys" Wil I get into any kind of trouble using these
vouchers ?
Pls help. Worried
Indiana Jones
Well I dont think the 50p off voucher works anymore as I tried it 3 times yesterday and it said they were all out of date but I used the £1 off everything method and ordered 5 dvds and so far 4 have shipped so I dont think they will do anything mate and if they did, the worst that could happen would be that they cancel your order.
WeirdFish
If you do get in trouble you won't be alone thats for sure :laugh:
marcowil
How do I use a discount voucher and an e-voucher in the same order. It won't let me enter both at the same time and get the two x £0.50 discounts
Indiana Jones
I dont think you cant use both, just use the website that gives £1 off dvds and then use a 50p voucher.
chris110
Sometimes you can get lucky and be allowed to use both if you click redeem voucher, type in both voucher codes, and then click go on the one, about 2 secs after thats tried loading click go on the other. Sometimes it takes both off, sometimes just one. Ive had it take both off before but also had it where it only takes one off.
E
Ewan
Hi!
Thanks for the replies:cool: I have 3 50p vouchers- will I be able to use them all at once:confused:
Indiana Jones
You can get them to email you an e-voucher and use that with one of the vouchers they put in with your dvd so you can get £1 off.
I just managed to do it and got a £16.99 film for £14.99 thanks to the £1 off dvd link and both of the vouchers :D
