CDT20R-T2L - 32DP Integration
Discussion in 'AV Receivers & Amplifiers' started by Mike-D, Oct 23, 2005.
Tags:
  1. Mike-D
    Mike-D
    Mar 20, 2005
    30
    Does the CDT20R-TL do the same clever stuff switching inputs, matching display brightness and going into/out of standby that the DVDs and T32 do?
    The manuals available on line do not seem to have been updated to the TL version, and the DP manual does not mention the CD player specifically. I believe that it does have a tagtronic connector, but can't find a picture to confirm this.
    Thanks in advance.
  2. Miron
    Miron
    Sep 26, 2002
    1,439
    Vienna, Austria
    +56
    Mike, I never saw any CDT20R-T2L with TagTronic connector.
  3. Mike-D
    Mike-D
    Mar 20, 2005
    30
    Thanks Miron. Having re read the info on the IAG site I realise that they have used 'TAGtronic' to describe the sync link. I had assumed this meant it had the bus connector as well.
    Thats Ok then. No temptation to bid for the one thats appeared on EBay!
  4. real batman
    real batman
    thats good then .... i wouldn,t want to bid against you :hiya:
