CD's rattle in the DVD Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by whatdoiknow, Feb 1, 2005.
  1. whatdoiknow
    whatdoiknow
    Hi there, just after Christmas I ventured into the world of DVD (better late than never) as my two boys were bought a DVD for Christmas. As if just dipping my toe in the water I went for one of the supermarket cheapies a Hikona (I think that's what it is I'm at work at the moment).
    Anyway it played the DVD we had no problems and played my CD's which I have to admit sounded quite good through my TV speakers, but trying a CD yesterday it sounded as if the CD itself was rattling away in the player, I tried several more and about one in ten seemed OK the rest rattled away.
    I will take it back to Tesco but has anyone any ideas what it might be so that I can sound very technical when I am explaining the problem to customer services.
    Thanks,
    Martin
    P.S. Do any DVD players have the ability to program and play selected tracks on a CD as this model wouldn't.
  2. Mose
    Mose
    Dec 1, 2004
    1,629
    Aldershot
    +149
    Martin,
    I have experienced this for the first time this weekend. I bought a copy of The Grudge and it isthe only DVD of nearly 1500 that I have that I have heard rattle in the transport of the player.
    Strange for cds and DvDs to do this, but I think it has something to do with the labelling of the disc. The copy of The Grudge has a vvery thick and heavily embossed label.
    I tried it on three other players around my house and all of them struggled to play this disc.
    Not sure if this helps!!
  3. whatdoiknow
    whatdoiknow
    Thanks for that Mose, I wondered if it had anything to do with labelling or the quality of the CD as the first one it did it on was one that came free with a newspaper.
    Anyway when I get home I will try some more CD's and I've also got hold of a couple more DVD's so I will try them.
    Regards,
    Martin
  4. GFS AV
    GFS AV
    Jan 28, 2005
    407
    16
    I would imagine you are more likely to get a problem of any kind with a supermarket budget player, than if you'd stepped up that tiny bit further.
    The Toshiba SD240 is available for about £40 now. My girlfiend has the older SD330 and it has never let us down yet. The SD240 has had excellent reviews too. If I was you I would try and return the Hikona, and go buy a Tosh 240. You will more than likely have it a LOT longer.
  5. whatdoiknow
    whatdoiknow
    Thanks for that I will see what Tesco's have to say.
    I didn't want to spend too much at the moment as in the next couple of months I will have to get DVD Recorder with HDD as I also produce videos to sell on a very small basis and I am being asked for DVD's now, but this would reside with my editing suite.
    Regards,
    Martin
  6. GFS AV
    GFS AV
    Jan 28, 2005
    407
    16
    If you bought your DVD player from Tesco, you will be able to exchange it for Tosh 240 there and then. I think they do them for about £45.
  7. whatdoiknow
    whatdoiknow
    Thanks again for that GFS.
    Martin
