CDDB Help
Discussion in 'Headphones, Earphones & Portable Music' started by degringo, Mar 2, 2005.
  1. degringo
    degringo
    I've currently got over 20gbs of Mp3's but not all of them have ID3 tags.
    Is there a program that i can run that will check the ID3 tags against the CDDB database and assign the ones that are missing with the correcxt ID?
    I hope there is as otherwise I'm going to have to spend a lot of time going and getting track names etc, which will be a real pain.
  2. mick's cat
    mick's cat
  3. twcheang
    twcheang
    CDDB needs an audio cd to work, it doesn't work on mp3 file. U can use mp3 tag editor to name the songs.
  4. degringo
    degringo
    Cheers and Bugga...
  5. budlynch
    budlynch
  6. degringo
    degringo
    I have found a superb little app called MP3tag which works wonders and can get information from CDDB database and amazon
    worth a look, just put in mp3 tag in google
