CD v DVD v SACD v HDCD v DVD-A v ???
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Johndm, Feb 21, 2003.
  1. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Think I'm losing direction.... Advice please!
    Well happy with my Sony VA555ES, but that's started me on the upgrade thing again.
    My Panny DVD RA82 plays DVD-A via phono 5.1 connections, and
    CD via the coax........
    My VA555ES wants a SACD CD player plugged into it......
    My ageing Technics SL-P770 CD player wants to be connected to the amp with its never before used coax or optical outputs......
    Do I really need a HDCD CD player......
    DVD-A from the Panasonic RA82 is VERY impressive, but how does it compare with a good quality SACD or HDCD CD player?
    Thanks in advance for any suggestions.
  2. iwatkins
    iwatkins
    Hi John,
    I run a Pioneer 656A and have a few DVD-As and a few SACDs which I run via the analogue outputs into the 555.
    To be totally honest, I can't tell the quality apart.
    I also use the 656A to play bogo CDs and it sounds great also.
    I would say if you like DVD-A multi-channel sound you will like SACD. And 2 channel SACD does sound much better than CD.
    However, I certainly wouldn't buy a dedicated SACD/CD/HDCD player at the moment (unless it was fairly cheap) as I'm still not sure where the DVD-A vs SACD war is going to pan out.
    Maybe consider a universal player (including DVD-Video) as there are a few more available in the past few months in various price/quality brackets. There may also be audio only versions, but I haven't really looked.
    Did that help ? I bet not a lot :D
    Ian
  3. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Hi Ian,
    Thanks for your views.
    Looks like I'll just dust off the old Technics CD player's coax output, and treat her to a nice new lead to the Sony;)
    To be truthful, so far I still prefer the normal stereo CD format for music. I've got a couple of DVD-A discs, but while very impressive for quality, they somehow seem..... sort of false sounding.
    A bit like the BBC news in Pro Logic....wrong sounding if you know what I mean?
    Going to see Midge Ure live in M Keynes tomorrrow. I'll be checking the sound system very carefully. And taking note if he decides to sing some songs from Rear left/right, centre rear left/right etc:D
    Cheers,
    John
