  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
CD to PC to MP3
Discussion in 'Headphones, Earphones & Portable Music' started by Taz, Sep 16, 2003.
  1. Taz
    Taz
    Hi all,
    I bought a CD and want to convert it to MP3 so I can listen on my MP3 player... How do I get it from CD to my PC in MP3 fromat. ?
  2. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    you need a ripper.
  3. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    try using kazza or win mx and searching for a mp3 encoder should be loads.
  4. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    And i'd like to do it the other way round. But can't.... help!
  5. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
  6. rOAdeh
    rOAdeh
    Jan 24, 2003
    602
    Winchester
    +5
    EAC (www.exactaudiocopy.de) + LAME
    et voila...
    lots of info on these very forums and on google if you want more detail. But essentially anyone who wants bit perfect rips and the best quality mp3 encoding - it's the only way to go.
  7. Taz
    Taz
    :smashin: Thanks thats done it :smashin:
  8. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Totally agree. It can be a bit overwhelming though for beginners, that is why i recommended CDex. CDex is simpler to use and also comes supplied with a LAME binary.
  9. quadophile
    quadophile
    Sep 6, 2003
    78
    11
    +4
    Another vote for EAC+LAME, no doubt it is the best combination there is.
    As for CDex I am not familiar with it but one of the other simple tool (which does CD->MP3 is dbPowerAmp Music Converter. I always recommend it to those who do not like to fiddle too much with the software
