CD replay ( bitstream or analogue)
Discussion in 'Blu-ray & DVD Players & Recorders' started by Wilf, May 30, 2002.
  1. Wilf
    Wilf
    Jan 11, 2001
    375
    Staffordshire
    +6
    Hi, I,ve being reading on or two DVD reviews and they seem to suggest that Audio CD's are best played through analogue connections rather than digital bitstream. I was under the impression it was the other way around. I use a SD210e with coax.
    Appologies if I've confused myself and I'm going to test it tonight to see if I can hear a difference.
  2. gazzerr
    gazzerr
    Aug 29, 2001
    180
    16
    Damascus
    I think the answer is it depends:clown:
    It depends on how good your DAC's are in your source component and amp, what your amp does with an analogue signal and the quality of the digital bitstream from the source.
    The only way to know is to experiment as you are going to do. I found using the analogue output from the source was better in my case.
    Happy listening;)
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I prefer the "digital sound", i.e. connected via optical or coaxial cable. Seems to be more cleaner and detailed to me.
  4. paiger
    paiger
    I have my CD player connected to the analogue CD in phonos on my amp. I have a Sony 940 which has an analogue direct mode, bypassing all the EQ junk. This to me sounds much better than when I tried optical. A more expensive amp may not have this problem though.
    S
