CD-R vs CD sound quality
Discussion in 'Hi-Fi Stereo Systems & Separates' started by thedoc46, Jul 26, 2003.
  1. thedoc46
    thedoc46
    What is considered the difference in quality between a copied disc and an original CD ??
    Cos it's digital theoretically there shouldn't be any. Unless not all of the bits are copied over..
    Or is the change soooo little it would be impossible for the human ear to distinguish.
  2. puddleduck
    puddleduck
    Jan 24, 2003
    1,853
    48
    Lake District, near as dammit
    +59
  3. Mr 928
    Mr 928
    thedoc46,
    You'd be surprised at the difference in quality. All the top end sound seems to be flattened when listening to a copied disc. I use both my Mirage Omnipolar floorstanding speakers and also being trying some Mirage Omni-Sat speakers (really bright sounding speakers), and boy can you tell - flat flat flat...
  4. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,072
    Newcastle
    +292
    Your copier, and / or CD-R's are crap.
    I'm not being funny mate, but its true. Mine are absolutley identical. Either that, or your mind is playing tricks on you ;)
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Not so sure about that,Paul.....once the copying is done,a lot comes down to the quality of the replay system and it's ability to resolve the differences between the copies and originals....I'd agree with Mr 928,and would also say that mine can easily show the difference between a copy and the original.
    There are lots of very good scientific reasons why there should be differences,and why they may or may not be audible,and most of them have been gone over on these forums at great length.
