CD player help required
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Slug, Jan 24, 2005.
  1. Slug
    Slug
    Feb 29, 2004
    My Micromega Stage 1 is playing up again. The disc drawer mechanism is faulty. I can open it manually and the machine will play but it's a pain that I won't be able to put up with for long.
    I want get back to the position where I have a fully functional CD player at least as good as the Micromega.
    Should I:
    Get the Stage 1 fixed again?
    Buy a 2nd hand mid to high-end player on ebay - any suggestions of what makes a good second hand buy?
    Buy a new machine - any suggestions of a budget machine that won't leave me feeling downgraded?
    Or should I give up and play CDs on my Pioneer 545 DVD player?
    Any thoughts?
    Slug
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Depending on what the rest of the equipment you are using is like, you could do a lot worse than buying one of these: TDA 1543 non os dac and connect it to the 545.
    Run a search on Google and see what all the fuss is about.
    They are quite often on ebay. Coast between £70 and £110. It'll be the best £100 or so you'll spend this year. I'm in the process of building/tweaking one at the moment. It's not quite the equal of the DAC64.... Yet!
  3. Slug
    Slug
    Feb 29, 2004
    Thanks for the advice on the DAC. It's certainly worth a thought.
    In the meantime I've had the cover off and cleaned and lubed the drawer mechanism with partial success. The drawer now opens as it should but needs a helping hand to close. I suspect the drive belt may have stretched a little.
    Any idea where I might get a replacement drive belt about 40mm diameter?
    Slug
  4. Slug
    Slug
    Feb 29, 2004
    Just to let you know I have sourced a replacement belt from cpc.co.uk and the drawer now works fine again. If anyone is interested the relevant part is AVBELT79 - cost 26p + £4.99 handling charge + VAT. A good deal cheaper than even the most secondhand DAC although I may consider that as a future upgrade now the drive works properly again.
    Regards
    Slug
  5. RohanM
    RohanM
    Jun 4, 2004
    362
    London
    +32
    Slug,
    My Stage 1 has the problems you appear to have fixed: drawer not opening/closing properly (and very noisy when it does); and occasionally 'skipping' on some tracks.
    What did you do to fix it?
