Cd player Head phone jack
Discussion in 'Headphones, Earphones & Portable Music' started by Nube, Dec 25, 2004.
  1. Nube
    Nube
    Hi. I got a new cd player, and the jack where you plug in headphones is giving me problems. When I plug it in I have to mess around with it untill it plays the music. Sometimes it goes mute because the wire isn't perfectly in the right position. Is there a way to fix this? Also its not the headphones.
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    If it's a new player,I'd take it back to the shop....sounds very much like either a dry joint on one of the wires to the socket,or a badly made socket.
  3. Nube
    Nube
    How can I fix it?
  4. JayCee
    JayCee
    Jan 20, 2004
    22,200
    Lanarkshire
    +2,313
    See #2
