Cd Player For Vauxhall Corsa (1999) - Help Needed!!!
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by abrown666, Aug 17, 2004.
  1. abrown666
    abrown666
    Hi there, Ive just bought myself a 1999 Vauxhall Corsa. I want to replace the rubbish looking blaupunkt tape deck in there with a cd player, but I see that there is a dash display showing the radio station you are on. Will this stop working if I put any cd player in? If so can anyone recommend a cd player that will work with this display? Cheers!
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Kenwood do units that work with the original Vauxhall display, not sure of any any up to date model numbers though..
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
  4. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,339
    +6,871
    As you probably know, you can buy a replacement fascia unit to allow the fitting of a standard DIN unit. I replaced the factory fit cassette player in the wife's Corsa (2001) with a Sony head unit. You lose the radio/track info from the car's display but you have it on the head unit instead. You will retain date/time function though.
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    See my above link!
    I have display info. with my Omega and a Sony MD player
  6. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,339
    +6,871
    The point I was making to abrown666 is that although it is possible to retain the radio/track display with the connects2 device you have suggested, it isn't actually necessary.
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    I didn't want to lose display - worth every penny
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    My missus has a Sony CDX MP40 MP3 single disc unit in a 99 corsa, dead easy replacement no adapters needed (she decided to do without display as lead was £40 and she doesnt have steering controls). CDX5700 is a nice unit see www.mcs-direct.co.uk excellent service and prices (check that model has OEM display option MP40 did, have a search as i researched this alot at the time. use corsa and MP3 as search options all you ever need to know, IIRC KEnwood and Sony lower models have OEM display options, not many others sub £500 do.
    http://www.mcs-direct.co.uk/acatalog/sony_cd_tuner_CDXF5700.html
    £149.95 2 year warranty (£10 shipping)
    MP3 in car is a really nice idea 14+ albums on a CDR!!! also plays CDRW and displays artist data etc!
    http://www.sony.co.uk/PageView.do?s...ctcategory=/In-Car/In-Car+Audio/ICA+CD+Tuners
    Need a sony brochure to check display option, MP40 had it, try local dealer or call MCS, they were very helpful when i rang.
  9. neil@work!
    [email protected]!
    I just replaced my Tape deck in my 2001 corsa with a Kenwwod KDC-W7031
    and its brill!!!
    You loose the radio display off the dash by it displays on the unit , the
    time and temp stay on the dash!!
    Its all good!! :)
