CD player directly into power amp?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Swinnydon, Mar 14, 2005.
  1. Swinnydon
    Swinnydon
    Dec 11, 2002
    342
    16
    Cambridge
    Hi all,
    Bit of a funny question so here goes... I have a tosh sd900e, a Rotel 1066 pre, and a Roksan Caspian power. Not entirely happy with the sound at the moment and wondering whether there's a fault on the 1066. Is it possible to connect the phono-outs from the tosh directly into the roksan for the most direct route?
    cheers!
  2. Tejstar
    Tejstar
    Dec 4, 2002
    23,016
    London
    +1,152
    Unless your Tosh has a pre-amp stage I would have thought not.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,672
    This can be done,using a passive preamp or some form of attenuator between the CD player,and the power amp.....if you don't,the CD player's peak output of 2V is very likely to at best overload the input stage of the Roksan(or any other power amp)and at worst may damage your speakers.
    I've used an Audio Synthesis Passive pre for some yrs for this,cutting out the use of an active preamp,with very good results,but the AS passives aren't cheap.
