CD or DVD-A input on AVR300?
Discussion in 'AV Receivers & Amplifiers' started by ginaandlee, Sep 19, 2005.
Tags:
  1. ginaandlee
    ginaandlee
    I have a DV89 hooked up to my new AVR300 which i use as my CD player and noted that to use the CD input as well as the DVD-A one i need to use both 2 channel outputs on the 89. I listen to CD in direct mode, does it make a difference if i just use the DVD-A input in 2 channel rather than a dedicated CD input, saving me the bother of using another pair of ICs? Im thinking no, but thought id ask anyways :)
