cd hookup to denon avc a1se
Discussion in 'AV Receivers & Amplifiers' started by perry ferrit, Oct 24, 2001.
Tags:
  1. perry ferrit
    perry ferrit
    Can anyone advise me on the best way to hookup my new marantz cd6000ki cd player to my denon avc-a1se amp. Phono, coax or optical
    leads. :confused:
  2. zcaps57
    zcaps57
    use good quality RCA cable.
    That's the best way. :)
    [ 25-10-2001: Message edited by: Amaris ]
  3. Jase
    Jase
    Mar 16, 2001
    10,804
    United Kingdom
    +2,693
    Using RCA phono leads means you´ll be using the DAC´s in the Cd player, you could also use the Optical or Coaxial cable as well. Then you can use the DAC´s in the A1SE, in Pure Direct mode it goes into Dual-differential mode and uses 4 DAC´s per channel for superb quality playback.
    Hope this helps
    cheers
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    For best CD-Sound use a digital connection, either optical or a 'digital' coax (75Ohm).
    If you find the DAC in the CDP superior use normal RCA interconnects.
  5. AVMAN
    AVMAN
    Go to your local dealer and buy e really good rca lead (analog).Reason being if you use a analog interconnect then you are using the dac in the player which is what you have paid the extra money for being a KI SIG.
    Dont use a coax/optical if you do you might have well purchased a normal cd 6000 ose.
  6. Lowrider
    Lowrider
    To connect digitally use a good coaxial cable, it does make a difference with CDs, not so much with DVDs...
    You should listen to the analog connection (RCAs), on direct mode, if you want to use bass management from the AV, or any DPS, it will be again converted to digital and back to analog, there I think you will be better off with the digital connection...
    Now compare both ways and use the one you like best, or both, depending on each music...
  7. zcaps57
    zcaps57
    I agree with AVMAN.
    I can see many ppl misunderstand about "sound quality" of CDPs.
    It is not so much about the DACs that cause serious serious difference in sound quality.
    I'm not saying DACs are not important at all.
    But.. it is more about the "lens" and "internal clock" that matters much more than DACs when it comes to sound quality.
    And as you know... this is often called jitter.
    I would say that connect your CDP with good quality RCA cables. Forget the DACs in A1SE.
  8. Lowrider
    Lowrider
    He can only forget the DACs in the Denon if he always uses direct mode, otherwise the signal will again be converted to digital, and back to analog, I say any conversion will change, degrade, so to use bass management or Dolby or DTS he is better using the digital connection...
  9. zcaps57
    zcaps57
    I agree.
    When you listen to CD in "Direct Mode" or "Pure Direct Mode" RCA cable is the way to go for serious stereo listening.
    What's the point of using DOLBY or DTS when you listen to 2ch stereo music.
  10. Lowrider
    Lowrider
    DPLII is very good for two channel, particularly TV, VHS, Radio and even CDs when the recording is not perfect or you doing casual listening.
    Plus you don´t get bass management in direct mode...
  11. zcaps57
    zcaps57
    I've nerver experienced DPL II.
    Still waiting for upgrade for my a1se.
    By the way, is DPL II better than DTS Neo ?
  12. Lowrider
    Lowrider
    I never tried DTS NEO, only similar from TAG and ONKYO.
    I prefer the sound of DPLII, plus it has two modes, Movie, that you cannot change, very good for movies and TV, and music, where you can change three parameters to vary the width, depth of the stage and volume of the center channel as you please...
