cd connection
Discussion in 'Music & Music Streaming Services' started by adox, Feb 5, 2003.
  1. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    has anyone used this site for purchasing cds?
    or can you recommend any other sites,apart from cdwow?
    thanks
  2. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    anyone.....................:boring:
  3. Squirrel God
    Squirrel God
    Adox,
    I use www.absound.ca LOADS, as well as www.cd-wow.com
    Have found almost everything i've ever wanted using those 2 combined and A&B can often be cheaper.
    For some US-only releases, I used Amazon.com, but you might always want to try www.playcentric.com
    I've not used CD Connnection before. Presumably www.cdconnection.com ? Might check them out but I see they're an Amazon merchant so probably the same prices!!
  4. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    thanks for the advice s.g.
    i usually use cdwow and have no complaints but the stuff i`m looking for at the moment seems to be only available in america. cd connection came up on the search as the cheapest, but i`ve never used them before. will look into the sites you`ve suggested to see if my wants are available.:smashin:
  5. Squirrel God
    Squirrel God
    If it's only US releases, then www.playcentric.com should do the job. Might not be the cheapest though.
    Don't forget to try Play.com as well :)
  6. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    thanks squirrel.
    had a look at all the sites and cd connection was the cheapest for the particular cd i was looking for.
    i went ahead and ordered it from them, so i`ll let you know what the service etc is like from them.
    thanks again for the help.
  7. Squirrel God
    Squirrel God
    Yeah please do mate. If they're good, I might start using them :)
  8. Enigma
    Enigma
    Nov 30, 2001
    24
    Just for everyone's information, I ordered a cd from CD Connections. It was dispatched on 03/03/03 and arrived on 10/03/03. Admittedly, this was my first order with them, but as they say - first impressions count! I will certainly use them in future.
    Gav
