CD Audio through AX10 (again!)
Discussion in 'AV Receivers & Amplifiers' started by Oasis-GasPanic, Jun 10, 2002.
  1. Oasis-GasPanic
    Oasis-GasPanic
    Sep 20, 2000
    552
    South West London
    +5
    I'm Sorry about this but I still can't decide. AX10 or A1sr. I can get the AX10 for £2000 and the A1SR for £2100 so theres not a lot of difference in price. So I think its going to come down to two things (1) If I was playing a CD through a Coax digital connection which would sound better (I know its a bit unfair due to the A1SR having a "pure direct" mode but does the AX10 really sound that bad, I was under the impression both amps had similar DACs. And (2) How easy are they both to setup. I know the AX10 has a slight advantage due to it having the MCACC feature but is the A1SR very hard to setup becuase even thogh I have had three high end amps now I wouldn't say I was great at setting them up.
    Cheers.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Not sure, but isn't the "Pure Direct" mode for analog sources only!?
    Just guessing ...
  3. Jase
    Jase
    Mar 16, 2001
    10,740
    United Kingdom
    +2,525
    It can be used for digital sources as well.:)
  4. Oasis-GasPanic
    Oasis-GasPanic
    Sep 20, 2000
    552
    South West London
    +5
    Cheers Jase, at least I know that if I do go for the A1sr the Pure Direct will work. BTW if anyone actually ownes or has heard the AX10 playing CD's in a reasonable environment could you please post your feelings on how it sound compared to your previous amp.
    Thanks for your replies, keep 'em coming.
  5. Oasis-GasPanic
    Oasis-GasPanic
    Sep 20, 2000
    552
    South West London
    +5
    OK I take it not one person on this forum has or has heard the Pioneer AX10.
    Thanks anyway:confused:
