CD Audio through amp - help required!
Discussion in 'AV Receivers & Amplifiers' started by bobcollege, Aug 29, 2005.
  1. bobcollege
    bobcollege
    Nov 16, 2002
    333
    Solihull
    +13
    Hi, I am playing my CD's in my DVD player via my old Sony STR-DE475 Amp. I wouldnt exactly call myself a home cinema buff and my system is setup on a budget.
    Now my problem maybe pretty simple for some to sort out. Obviously the cd's are in stereo format but using the two front channels they lack depth from the lower frequencies from my bookshelf speakers. My question is regarding Pro Logic II, I know Pro Logic II uses your front and surrounds but does it use the Subwoofer?
    Snaily
  2. Astaroth
    Astaroth
    Jun 22, 2004
    2,283
    63
    London
    +117
    Prologic II can use your sub depending on how you set it up. With my Denon AVR I can also instruct the AVR to use the sub when playing stereo music - may be worth looking at as I personally dont like making surround sound out of stereo
  3. bobcollege
    bobcollege
    Nov 16, 2002
    333
    Solihull
    +13
    Thanks for the prompt reply, managed to get the sub working after a little investigation :)
