cd 73 problem
Discussion in 'Arcam Owners' Forum' started by srbwilson, Sep 21, 2004.
Tags:
  1. srbwilson
    srbwilson
    Jan 6, 2004
    298
    hi guys, hope you can help. just purchased a cd73 t second hand, did a demo and everything seemed ok, till i got it home. the player some times fails to pick up a the cd or just keeps saying loading. othertimes it is fine. a quick turn on off seems to do the trick. the player is only 6 months old from superfi, so should i be able to get it sorted under warranty?
    any help would be gartefull
    regards
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,400
    Rainham Essex
    +2,452
    You should have no problems getting the CD73 repaired under warranty as all Arcam gear comes with a 2 year transferable warranty.
    Mark.
