ttcctv
Hi.
Hope someone can help me.....??
CURRENTLEY I have a analoge cctv system installed which consists of:-
4x HD TVI 2mp 1080p Qvis Dome 30m Night vision Cameras
Avtech AVT204A DVR
Running on Coaxial Cable + Seperate Power Supply for each camera.
The 2 CCTV fitted lower down on the house have an intermitant problem. Sometimes do not show, sometimes black and white and at other times very dark or fuzzy. I believe the DVR is faulty as the Vidio out bnc connector for the TV broke and I tried welding it on but wasn't very successful.....
I am thinking of buying a Hikvision NVR instead of a DVR to run the same current cameras and then in future I can just swap the cameras for better cameras. I want to know if I buy an NVR what else will I need to run the current analouge cctv cameras off the same coaxial wire? Is it even possible? Do I just get a analoge to digital signal converter (bnc to rj45) for each camera (how much do these cost?) and use the orignal power wire to power each cctv camera?
Please help?
Avtech AVT204A DVR
Please help?
