CCTV Imput to Plasma
Discussion in 'Plasma TVs' started by lurcher, Jun 6, 2003.
  1. lurcher
    lurcher
    May 15, 2003
    4,113
    Stalybridge
    +202
    Are there any problems associated with feeding a security camera imput to a Panasonic plasma screen (not on a permananent basis, occasional monitoring ) ?.
  2. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    None what so ever, its just a composite signal, connect either by phono plug or preferably bnc.
    If you have enough inputs it can be plugged in permanently and just switched to when required.
  3. lurcher
    lurcher
    May 15, 2003
    4,113
    Stalybridge
    +202
    JohnS,
    Thanks for the quick response.
  4. GaryB
    GaryB
    Nov 12, 2002
    5,345
    St Albans
    +1,266
    I know you mentioned it is just for occasional monitoring but bear in mind the possibility of burn in. If your CCTV picture has any bright bits it won't be long before your plasma has them permanently. If your plasma has any burn reduction stuff built in, make sure you use it.
