CCTV help
Discussion in 'Smart Home, Climate Control & Security Forum' started by nick67, Sep 12, 2007.
  1. nick67
    nick67
    Dec 17, 2004
    2,388
    83
    East Sussex
    +285
    Need to install a simple one camera with DVR system into a small shop.
    Can anyone recommend a system please
    New to this so unsure of requirements other than above
  2. nwatson6
    nwatson6
    Oct 18, 2005
    37
    11
    +5
    try looking here:
    http://www.rfconcepts.co.uk/cctv cameras.htm
    I have a CC70 used outside, but you need to decide what light level you need it to work in. There are domes, bullet cams, your choice. A lot of retail shops seem to use domes.
    There are several recorders to choose from again it depends if you want network access etc.
    http://www.rfconcepts.co.uk/digital-recorder.htm
    I am not saying this is the best place to buy from, but it gives you a good idea of what is available. I personally used a spare PC with a Geovision card to allow remote access, recording etc. Nice but can be expensive.
  3. nick67
    nick67
    Dec 17, 2004
    2,388
    83
    East Sussex
    +285
    Thanks for the links shall check them out
