New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
just installed 4 cameras the guy i bought them off suggested i buy a 500 gb hard drive dvd r of him i thought it expensive at 800 euro. what does anyone think any other good options,
You can get your own 500GB hard drive for a lot less then that! try ebuyer.com! If your hooknig them up to your computer that is really the only answer get a big hard drive for storage, but you can get some devices that will record the camera to its own hard drive (just like a pvr) and allow you to view it back via your TV. What type of connectors do the CCTV camera have?
sounds like thye're designed to back to a pvr rather than being network capable.
You will need a pvr that has four inputs. I looked into that but found them all expensive. You usually match the pvr make to the same make as cameras - thats probably what he was selling you, not just the hdd.
I went with network cameras and built a linux server to poll the cameras for images.
The other thing you could do is buy a card for a pc with 4 inputs and then use that to record the images
I use an old PC (3Ghz P4 2Gb ram) with a Geovision card, two hard drives, one for windows and software, other used for video storage. Both drives are 80gb and I get plenty of video recorded, so not sure why you would need 500gb, I can see a need with lots of cameras (I have 4). I access the PC wirelessly via ultraVNC, reliability is very good.
In that case go for the £300 unit it has all the nice bits cut from the £99 box which is more like £150 once you add a drive so the more expensive unit is the better value.
Cheapest way out for me was using an old PC ( someone you know MUST be upgrading soon ) - Buy a DVR Card from fleabay I got a decent 8 channel DVR for around £50 ( the sellers in HK usually offer the better deals if you are prepared to wait the extra few days ).
I use Logmein ( logmein.com free version ) to access the PC remotely. You can even control the Pc's mouse to send emails from that PC to yours - never tried it but i'm sure youd be able to compress a video file ( if not too big ) and email it to yourself, etc..
