Cctv and remote viewing (dns) help needed
bonerp
I have a cctv system and I've linked the dvr onto my home network.
I use BT infinity and have a hh5.
In Reading stuff about how I can access it remotely on my Android device, I understood I needed a dns as my ip address is not static with BT.
So I set one up with dyndns. This monitors mine and keeps it aligned(?).
Problem I have is my ip is currently 86.174.nn.nnn.
Dyndns is changing it to something different - 95.258.nnn.nnn which means they are not aligned.
This means I can still currently access it on 86.174......by entering it into a web browser. But not using the dns I have. Ie Bonerp.dyn.dns.
There's something else too... Dyndns implies I need to use an updater which kinds of defeats the object of keeping my ip address doesn't.
Can anyone help. I'm not getting the point of the dns if I need to keep it updated by running an updater. It's not allowing me to access it whenever I want as I need to ensure the ip is correct first!
EndlessWaves
A major point is to centralise the change. If you were running a web server for example, you'd give out the Bonerp.dyn.dns address just once instead of having to send everyone interested in viewing your web page a new IP address every time it changed.
The automated updater needs to be run on the system you want the URL to point to. In this case a computer always connected to your home network. If you're trying to run it on your android device when you're connected to another network then that's the cause of the error - it's pointing the address to that network rather than your home one.
bonerp
Oh so my laptop needs to stay on all the time to allow it to sync?
