CCTV 4 & CCTV E & F (Intelsat 1R 45 W) on PACE DS 810 XE
J
j.puig
I have a Pace ds810xe HD receiver, and I'm not able to get any sound on both chinese channels on PAS (Intelsat) 1R at 45West.
If i use other receivers, I get audio perfectly, but using PACE it doesn't !!!
Has anybody already noticed it ?
Regards,
Chris Muriel
According to http://www.lyngsat.com/intel1r.html those channels use audio PIDs (Program IDs) of 1120 and 1220 respectively.
Does the Pace 810 allow you to manually insert the audio PIDs (sometimes abbreviated to APIDs) ?
Can you hear audio from the Chinese radio station (APID 1122) ?
If I was at home I`d check it on my own recievers.
Certainly both channels are listed as FTA (Free To Air) so you should be able to get audio.
Chris Muriel, Boston (normally Manchester)
J
j.puig
No, the pace doesn't let you insert manually PIDs.
Other receivers get sound perfectly.
Regards,
Chris Muriel
In that case I would suggest that you post your problem in the High Definition forums here; there's a couple of threads there already about the Pace and its software upgrades (so you will find other owners there).
Samsung QN800B 8K TV Review
