CCF files
Discussion in 'Home Cinema Control & Remote Controls' started by dantilly, Dec 16, 2002.
  1. dantilly
    dantilly
    Does anyone have the ccf files for the following conponents
    Panasonic TH-42 pw5
    Denon av10 se
    Denon dvd 2800
    Pace sKY BOX
    tOO LAZY TO DO THE HARD WORK:D
  2. graham.myers
    graham.myers
  3. cadmeister
    cadmeister
    Nov 12, 2002
    107
    19
    Milton Keynes, UK
    There's certainly a Neo config for the Panny plasma on Remote Central as I'm using it.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,629
    +4,906
    I have the Denon AVC 10SE which I found on remote control central along with a Pace box.
    If you PM me your email addy I will gladly send it over.
  5. Gloves
    Gloves
    HI
    I am new to all this, hope someone can help, does anybody have a ccf for the Denon DVR 2805 AMP, I have looked on remote central and cant find it
    Hopefully
    Gloves
  6. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    I have CCFfor denon 3300 amp which is very similar to the 2805 so I think there's a pretty good chance that the codes will work. I also have codes for panny 42 pw7 with discrete on off, inputs, aspect ratio which are likely to work on the pw5. My CCF is for a pronto classic, not NG. If any of you want it I'd be happy to upload or e-mail.
