I've downloaded the pronto edit software with intention of building a set for these systems to use with the PDAWin software: Sky+ Tivo Sky Digibox Sony TV Yamaha DSP-A2 Amp Sony NS700 DVD Player Panasonic DMR-20e The problem is that I cannot get my head around how to program it! In the unlikely event that someone has the same systems it seems I need a volunteer to build one for me, I'll pay a reasonable amount for the work involved! DaveP
Hello DaveP I believe the iPAQ uses Pronto ccf's without any modification, so your best bet is to look in either the component or system ccf files at Remote Central http://www.remotecentral.com/files/main.htm for your bits of kit. If you download a system ccf & open it with Pronto edit you should be able to see how it's all stuck together. You can then download existing ccf's for all the devices you need. You'll only need to make a home page to link to them all & there's an excellent faq section on the same site to guide you through the software. Cheers, Paul
If I find my device as part of a complete system, can I "export" that particular bit and then add it into my system? If so how? Thanks DaveP I know - it's in the FAQ (just found it!)
