ccd size
Discussion in 'Photography Forums' started by nobackwheel, Oct 8, 2004.
  1. nobackwheel
    nobackwheel
    Sep 24, 2003
    85
    ascot
    I think i'm right in saying that the bigger the ccd, the better right?
    what i'd like to know is what does 1/1.8 inch or 1/2.5 inch mean?
    does that mean it's 1 x 1.8 inches square? i.e. 1/2.5 is bigger (therefore better) than 1/1.8??
    cheers,
    Ste
  2. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
  3. nobackwheel
    nobackwheel
    Sep 24, 2003
    85
    ascot
    cheers keanyboy - why do we still use silly imperial measurements!!
    the website actually says that 1/1.8 is bigger than 1/2.5 - so good job i checked!
  4. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    There's been issues about cramming mps on small ccd's leading to noise. Say you stick 7mp on a 1/1.8 you may well get better image with a 1/1.8 5mp censor more room means bigger pixels means less chance of noise
  5. Garrett
    Garrett
    Apr 21, 2001
    40,203
    2
    167
    The best thief you’ll never see.
    +6,652
    You link is not working at present.
    I was reading a few months back and they said they had not advanced with the sensors as much as the mp size and really getting an 8mp camera was a bit waste of time and round 5 mp gave as good a results.
  6. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    The hole sites down at the mo Garrtett.
  7. Garrett
    Garrett
    Apr 21, 2001
    40,203
    2
    167
    +6,652
    So is your keyboard from the above. :D
  8. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    I kinda like Garrtett :p
  9. sorbiegunner
    sorbiegunner
    Jan 16, 2004
    184
    You must remember that the ccd is the equivalent of the 'film' ie what captures the image. If you think back to old pre digital days there wasn't a helluva lot between one branded film and another, but the quality of your lens could make a really big difference, well now the difference is that not only can the quality of your lens make a difference but you can't pick and choose the quality of your 'film' (ccd).
    But don't dispair if you buy a camera with a quality lens then you will also have a good quality ccd (for the money).
