CC40R filter?
Discussion in 'Projectors, Screens & Video Processors' started by rhinoman, Jan 28, 2003.
  1. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Is there anywhere to order this online in the UK?
  2. avanzato
    avanzato
    Jan 21, 2003
    1,963
    Norfolk
    +82
    I was looking for Neutral Density filters and found this place last night SRB Filters they list Colour correction filters too.
    It looks like they have a secure order form but I've been very busy at work today so haven't contacted them yet. So can't say what the service is like.
    Has anyone else bought from them?
  3. chris thomas
    chris thomas
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I'd like it for my new HS10:D
  5. graham.myers
    graham.myers
    I'm llok for a CCR filter for my 10ht. My neightbor has got an 11HT with a CCR40. I was thinking of a 30
    which would you recommend?
    Not hijacking your thread John - just hoping for some insight
  6. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    No problem Graham, judjing from the low response I suppose I might have to have a trudge round some real shops.:(
  7. John_N
    John_N
    I've been hunting around for an HS10 CC40R filter that screws into the lens like the one supplied.
    Not been successful.
    According to my ruler, the supplied filter is a 67mm filter which is a standard camera size according to the chap I spoke to in a local camera shop.
    However - he didn't manage to find me a CC40R filter in that size. The kodak gelatin filters appear to come in squares of various sizes.
    I think that a number of the gelatin filters can be cut. One solution might be to obtain a 67mm filter fitted with optical clear glass and then cut out the filter and fit 'on top' of it. This would at least mean it could be removed / swapped whereas cutting it out and jamming it in the actual projector lens I feel is a bit heath-robinson.
    If anyone has found a supplier doing a CC40R filter in the size for the HS10 then please share ...
    I'm taking the filter to the camera shop to see if it really is a standard 67 fitting. I'll let you know.
  8. Meridius
    Meridius
    Dec 23, 2002
    3,997
    +206
    here you go, i have sent an email to this supplier and he told me a custom lens fited filter a cr40r will be out next week for $64
    about £40 i did get a cc40r 4x4 filter and it realy do`s a good job
    it takes out the blueish black to a dark gray and maeks the whole picture alot better it reduces the picture brightness a littile but not much its still bright
    the address is http://www.enhancedht.com/
    ittook 7 days for mine to come but now going to order the custom fitted version which screws onto the lens its out next week he hopes
