Caution warning on 1906
Discussion in 'AV Receivers & Amplifiers' started by rob roberts, Jan 2, 2007.
  1. rob roberts
    rob roberts
    May 7, 2006
    89
    +4
    I went and purchased new speakers yesterday to upgrade from Kef Kht 1005
    to a pair of Kef cresta 3's and Kef Q6C centre, but when I tried to run auto setup on my 1906 the front left channel played the test tone and then came up with "caution FL" and will not run the rest of the setup.
    Anyone have any ideas or solutions to this.
  2. Jase
    Jase
    Mar 16, 2001
    10,873
    United Kingdom
    +3,087
    What else did it say? Caution FL - None, Phase??
  3. DenonReceiver
    DenonReceiver
    Dec 14, 2005
    36
    +3
    1. Wrong cabelling /reversed polarity, short-circuit, etc./
    2. Bad speaker cables.
    3. Bad speaker.
    4. Bad receiver /least possible/
  4. scottyule
    scottyule
    Mar 6, 2006
    179
    Portsmouth
    +6
    Did you sort it??
    My thoughts would be to swap a few of the speakers round to see if it's a speaker problem or cable problem.
  5. Atchi123
    Atchi123
    Jun 8, 2006
    483
    28
    +42
    The 1906 auto setup often detects Kef speakers as out of phase due to the uniQ drivers for some reason. You should be able to skip past that error message I think.
