Cats in trouble! Ruarks damaged
Discussion in 'Home Cinema Speakers' started by pwood, Mar 26, 2005.
  1. pwood
    pwood
    Dec 6, 2003
    2,481
    Central Scotland
    +136
    Okay first off the grills are now needing replaced and I wondered if its possible to get a more resiliant speaker cloth to recover them with. However cloth is cheap drive units aint and as the cloth pushes in slightly the wee bam has got a claw into the rubber diaphram on my midrange unit (Ruark Talisman2) it has resulted in a slight tear about 2mm. A blob of glue would probably stop it getting bigger but I know certain types of glues react badly on certain rubbers I was hoping someone could advise of a suitable one.
    In time I will no doubt have to replace the midrange drivers I take it Wilmslow Audio is the best place to approach.
  2. bob1
    bob1
    Nov 7, 2002
    4,324
    Sheffield
    +129
    I use some rubber glue at work ,can't remember the name but when i get back i tell you what it is .
    Its very strong and the bond is stronger than the rubber ,i know i tried it and the rubber broke in a different place to the bond.
  3. pwood
    pwood
    Dec 6, 2003
    2,481
    Central Scotland
    +136
    Cheers.
  4. bob1
    bob1
    Nov 7, 2002
    4,324
    Sheffield
    +129
    If i don't get back to you on tuesday night remind me cos i might forget.
  5. Mr Grumpy
    Mr Grumpy
    Jan 12, 2005
    377
    TBC
    +9
    Well you're a lot more understanding than I would be, I get mad enough when I find muddy paw prints acrsoss the telly or sub but if the g/f's cat ever did any actual damage.......well let's just say he'd be very very sorry :mad:
  6. giosblue
    giosblue
    Ditch the cat.
  7. Stoatman
    Stoatman
    Jan 26, 2005
    1,014
    +90
    I would tie it to a subwoofer and play 'saving private ryan', let the kit gets its own back.
  8. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    get a dog :D
  9. pwood
    pwood
    Dec 6, 2003
    2,481
    Central Scotland
    +136
    Believe me guys I had to be restrained by the missus when I made THE DISCOVERY :mad:
    The problem is even thought the grills are on, the distance between the cloth and the rubber surround on the drive unit is not enough especially now the cloths seen better days.
  10. pwood
    pwood
    Dec 6, 2003
    2,481
    Central Scotland
    +136
    Wouldnt work as shes a hard core av fan :rotfl: Just no brain when it comes to the night time run around.
  11. pwood
    pwood
    Dec 6, 2003
    2,481
    Central Scotland
    +136
    Quick update for anyone who needs a replacement drive unit. Wilmslow Audio are the best bet as they just quoted £44 for a new woofer which is far less than I was expecting :clap: Once I've covered the grills in some new acoustic cloth sourced from maplins I'll be able to get a new units if (when) the sounds starts to degrade. In the meantime I'll probably try a bit of glue to see if it will stop the small tear getting any worse.
  12. bob1
    bob1
    Nov 7, 2002
    4,324
    Sheffield
    +129
    The stuff we use at work is Loctite 406 .
