Hi all,
I’m hoping someone can help, I’m currently looking at setting up a wired home network. At the moment I have FTTP BT 900mbps internet service and have the following network products;
Ubiquiti Dream Machine Pro
Ubiquiti 16 Switch PoE
Ubiquiti U6LR access point
I’ve been looking at Cat6A seems the best option to provide a degree of future proofing and cost to performance.
All of the equipment will be housed in a 6U data cabinet with patch panels etc. and stored in my loft.
The issues I have are as follow;
What 6A cabling should I be looking to get, the wiring will be both internal and external so may need two types of cabling - any recommendations would be welcomed.
What crimping tool should I be getting as unfortunately the equipment owned all runs in RJ45 so can’t take any other option.
What connectors should I be getting that will be compatible with the cable and crimping tool.
I’ve been looking everywhere and am struggling to figure out what to get. I should add that I’m based in the UK.
All help really appreciated. Thanks in advance.
