Cat6 Faceplates
dansflow
Hello all,
New member with my first question.
I am doing an install and want to match the cat6 modules to my other sockets, i am looking for a chrome plate with a grey plastic module for the cat6 outlets.
I have considered the possibility of buying white and spraying them to grey but i hoped there would be a pre-made solution.
Thanks for any and all help
mickevh
To name check just a few of the "big boys" that come to mind, try Black Box, CPC, RS Components.
With fancy finished, sometimes you have to comprise and use a modular system. Thusly, you can get the bezel in chrome (or whatever) but the actual jacks are still white (though I'd look for black - it'll probably look better next to chrome.)
dansflow
Thanks for the reply mickevh i will have a look, i wondered if someone on here might just say go "here" they have those
Podcast: New Denon AV Products, HDMI 2.1, 8K, DTS:X Pro Sound Q&A with Denon Product Specialists
