Cabling is going to be used for vision (currently AVAtrix), audio (currently A-bus), telephone and data.
Not interested in Cat7. Only considering Cat5e or Cat6.
Recognise the only benefit of Cat6 over Cat5e is that it can transfer more data so had consider putting in Cat5e to TV and speakers and Cat6 to telephone/data points but then I thought as the wire cost difference is little why not just install Cat6 everywhere for increased flexibility.
There is still a big difference in switches etc when comparing between Cat5e and Cat6 so I had also thought I would install Cat5e equipment now and upgrade in future.
Saying that...my question is...do you think I will be using increases data transfer within the next 5 years...if not, why even bother with the increased cost of Cat6 wire?
