Cat5e faceplate.
Discussion in 'Networking & NAS' started by AciidSn3ak3r, Feb 11, 2009.
  1. AciidSn3ak3r
    AciidSn3ak3r
    Jul 9, 2007
    679
    Leeds
    +75
    Hi. Ive just bought some Cat5e faceplates for my home network install.
    And ive stumbled accross a little snag.
    When wiring them up it has two options to switch around with the wires.
    I can have option A which will wire up in this order.
    Green/White
    Green
    Orange/White
    Orange
    Or i can have option B with this order
    Orange/White
    Orange
    Green/White
    Green
    These are the left side of the module. The right side only let me do it in one order which is:
    Blue
    Blue/White
    Brown/White
    Brown
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Thats normal for both A B spec the blue and brown cores stay in the same place you need to wire for B spec both for normal networks A one and B the other is a crossover cable
  3. AciidSn3ak3r
    AciidSn3ak3r
    Jul 9, 2007
    679
    Leeds
    +75
    So for a normal network. Which its just coming from a standard switch. I need to wire it up to the B section?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Yes but wire blue and browns as well
  5. AciidSn3ak3r
    AciidSn3ak3r
    Jul 9, 2007
    679
    Leeds
    +75
    Yeah ive done the blue and browns. I was fine about that. Ive done this sort of thing before but cant remember the order for cross overs etc.
    Thank you for the speedy response. Will let you no how i get on :)
  6. AciidSn3ak3r
    AciidSn3ak3r
    Jul 9, 2007
    679
    Leeds
    +75
    Works brilliantly. Thanks again :)
