Cat5e Cable
russellwood
After many reason for not being able to start running data cable, the time has come where i can. Got some cat5e network cable at a very very cheap price. Just want to make sure it is ok to use before i run it all around my house.
This info is for the cable taken off the krone website
A crucial component of ADC KRONE's impedance matched TrueNet® structured cabling solution. This cable guarantees Category 5e performance. TrueNet® LSZH horizontal cable is available in standard 305m boxes and 1000m reels and has a fire-rating of IEC 60332-1.
  • Product Description: Cable Horizontal Category 5e LSZH, UTP 305m Reelex, Orange
  • Product Number: TN5ETZ1-ORMI
  • Application: Horizontal Cabling
  • Length: 305m
  • Colour: orange
I will be running 2 data cables to each tv point(furture proof), 2 Coax cables to each tv point. Some points will also have VGA and usb cable to them (kitchen touch screen), Each room will also have 2 extra data cables for telephone and internet.
HDMI run from Node zero, to lounge tv, About 5m.
Can anyone think of anything i may have over looked.
Russell
Blump
Established Member
Plan :)
Rewiring is a great thing to do but it's kinda a one time only thing you can do so once you've settled all the furniture in, plastered and painted etc you can't really do it again if you suddenly say "dang, i wish i added X".
A few years ago I did a similiar thing and the only thing I forgot was a headphone wire from the amp in the attic to into the lounge.
benmc
Established Member
russellwood
that cable should be perfect.
Put in more than you think you will need as adding more later will be impossible
Ben
Andy8421
Established Member
Russell,
While there is nothing wrong with your plans today, unless you plan on moving, it is likely you will end up recabling.
I was an early adopter, way before Cat5 and HDMI, but I had the good sense to run conduit and cable tray throughout the house.
I am now on my third recable, and have managed to do it with little more than lifting a few floorboards.
If you have the chance, I would worry about running conduit and trays, and then just pull the cabling as you need it.
Andy.
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
