Cat5 link between xboxes
Discussion in 'Xbox Forums' started by Triggaaar, Sep 19, 2005.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    When linking 2 xboxes together, does the Cat5 cable have to be in one piece, or can it be patched (ie, from each xbox to a patch panel, and then patch the 2 sockets together)?
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    The cable has to be a crossover type, unless you have got a router/hub that will do it for you. It doesn't have to be one piece of cable, as long as the send/receive is swapped over (if I remember correctly)
  3. Razor
    Razor
    Dec 15, 2004
    37,563
    2
    +12,432
    A cross over is needed. :)
  4. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    Excellent, cheers for the quick responses. I'm going to patch the cables from around the house tomorrow, and it's nice to know I don't have use a continuous wire - means I can put the 2nd xbox in any room. I just need 1 cross over patch cable.
