Cat5 Help please
Discussion in 'Cables & Switches' started by Tug100, Oct 27, 2004.
  1. Tug100
    Tug100
    Oct 2, 2004
    20
    I've been following the instructions on the forum, trying to get hold of some Cat5 cable from Maplins, to make my own speaker cable.
    Problem is Maplins are out of stock (web site stock levels are a decoy).
    All my other bits are arriving tomorrow and now no speaker cable. Can I get the Cat5, to the right spec, anywhere else????
    I was looking for enough to make 30m of cable (not sure whether to biwire or not yet).
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    This isn't a joke right ? I've not seen the thread, but wouldn't CAT5 melt with a half decent current flowing through it ?
  4. Tug100
    Tug100
    Oct 2, 2004
    20
    Is the stuff you recommend going to give the same performance as the maplin stuff? I'm a newbie so help appreciated.
    The Maplin answer was that there's no stock at any depot.
  5. Tug100
    Tug100
    Oct 2, 2004
    20
    Ianh64 - do a search there's a really long thread with detailed instructions and a lot of positive feedback.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    i ahve no idea i just ran 79+ meters of it and it was fine for networking... I'm too lazy to make speaker cable out of Cat5.............
  7. Tug100
    Tug100
    Oct 2, 2004
    20
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    cat5 can carry a decent DC voltage and current as used in Muli-room system...
  9. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    No Ian not a joke as the link shows, Ive been using CAT5 for a few years now, I use 6m runs of the stuff on the end of a Primare A30.1 amplifier with 100W of pure amplification, quite a few other audiophile use it too, those that do and are happy with it are very lucky because it cuts them out of the cable hype crap of this hobby at an early stage, so count yourself lucky about finding out about it. You too may be converted.
    Good link here :
    http://evildonut.34sp.com/diy/FFRC.html
    ATB
  10. Tug100
    Tug100
    Oct 2, 2004
    20
    Will any old Cat5 do the job?? ... or does it need to be LSZH - Low Smoke Zero Halogen (the product recommended in the link).
    I need to buy cables tomorrow so any input tonight gratefully received.
    Might use twin and earth instead (accepting that it is inferior), with the option to do the Cat5 thing some time soon.
  11. danburbridge
    danburbridge
    any cat 5 will do really - just so long as its solid core and not multistranded - you can also use cat6 (same cable just made to a slightly higher spec for faster data transfer)
  12. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Cat 6 would be good. Haven't made any yet but due to the faster data transfer capacity. I would imagine the copper would be of a higher grade. Which couldn't hurt.
    Only one thing. Try and get the most flexible Network cable you can. It's much easier on the fingers over long lengths.
