CAT5 Component Cable
Discussion in 'Cables & Switches' started by mince bigalow, Jan 16, 2005.
  1. mince bigalow
    mince bigalow
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I would be very concerned about the inter-wire capacitance of this cable, because the effect would be the deterioration of high-frequency signals, leading to a "wooly" picture. I suppose if you have time on your hands, you could give it a try - it won't cost very much.
  3. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    I would have reservations due to the capacitance of the cable and the fact that there is no shielding of any kind. But hey if it works......
  4. mince bigalow
    mince bigalow
    Cheers for the advice guys. So how come CAT5 is great for speaker cable but not for video cables then? And also how does capcitance affect the quality? Also how exactly does cable have capacitance? I remember from A Level Physics that capacitors store charge and then release it over a period of time. How does that relate to just normal cable?
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Normal CAT5/LAN cable is unshielded, but there are in fact two types: UTP (unshielded twisted pair) and STP (shielded twisted pair).
    However a true coaxial cable with 75 Ohm impedance would be my first choice for video cabling. For DIY see this thread.
    BTW: Any cables is great as speaker cable IMHO, given you compare same diameter and material.
    Wires running parallel to each other (or any other kind of conductor, even the tracks on a PCB) represent a capacitance, albeit a very small one.
    This is the same effect as used for the electronic component called capacitor; an electrolyt capacitor is nothing but two conductors, seperated by an isolator, furled / coiled up (?) in a small housing.
  6. mince bigalow
    mince bigalow
    Ahh, so you mean that the signal can creep across the wires and spoil it? That makes sense.
    Thanks for the info :)
