Cat5/6, Coax, speaker cable, twin and earth in close proximity
Discussion in 'Smart Home, Climate Control & Security Forum' started by Rick2102, Jan 11, 2012.
  1. Rick2102
    Rick2102
    Nov 2, 2011
    339
    28
    +46
    Was wondering if anyone could clear something up for me with regards to the title ASAP as I have run quite alot of Cat5e UTP and am now a bit worried.
    I know you shouldn't run Cat5e/6 near twin and earth as the electro magnetic field from the twin and earth reduces performance on the data cable. I have read/heard different things with regards to how close they can be, and also isn't it dependent on if it is UTP, STP, FTP?
    If the Cat5e cable is within 50mm of the twin and earth can you cover the Cat5e with something to help it not loose speed?
    As coax carries power if this is close to Cat5e/6 does this create an issue?
    Do RCA cables and Cat5e/Cat6 cause interference?
    Sorry lots of questions just want to be 100% on the above.
    Thanks :smashin:
  2. Rick2102
    Rick2102
    Nov 2, 2011
    339
    28
    +46
    128 views, please could some one come back to me?
    Thanks, Rick.
  3. supraTTman
    supraTTman
    Feb 1, 2011
    1,007
    Portsmouth, Hampshire, UK
    +166
  4. Rick2102
    Rick2102
    Nov 2, 2011
    339
    28
    +46
    Cheers supraTTman. Geps kindly sent me this for anyone else interested:
    Installation Type - Minimum Separation Distance: - :Without Divider: - :Aluminum Divider: - :Steel Divider
    Unscreened power cable and unscreened data cable: 200mm : 100mm : 50mm
    Unscreened power cable and screened data cable: 50mm : 20mm: 5mm
    Screened power cable and unscreened data cable: 20mm : 10mm: 2mm
    Screened power cable and screened data cable: 0mm : 0mm : 0mm
