Cat Flap in bifold doors?
mr starface
We are in the middle of building work for new kitchen diner and will be having bifold doors fitted.
Currently we have a catflap fitted on our French doors but these will be going
Has anyone fitted a catflap in bifold doors? Is this possible without affecting the folding up of the doors? Don't really want one in our front door or a hole in the wall.
Expecting it to cost a bit but as we need one will have to bite the bullet.
JimmyMac
Have it put into one of the glass panels, seen it in a couple of houses like that and doesn’t seem an issue
MrFraggle
Are they double glazed if so that could cause an issue as I believe the gap between the panes of glass is filled with argon gas and fitting a cat flap unless done by the door manufacturer would break the seal and condensation might occur?
You'll need a new glass pane manufactured with the correct hole cut out and sealed into it - anyone who tells you that it can be done by cutting a hole in afterwards is talking out their rear.
IronGiant
They will be tempered glass so you can't just cut a hole in it without it shattering, you have to have a new panel made up with the correct sized hole in it, with those edges also sealed.
I'm assuming the doors haven't been ordered yet so they can probably specify having a cat flap hole when they do so.
I assume the bulky side of the flap will be on the inside so if you can get doors that open inwards and put the flap in one of the end panels so that when the doors concertina the flap won't be trapped between two panels. If you have to have outward folding panels you'll need a low profile flap.
mr starface
Thanks all doors haven't been ordered yet so from sounds of it can hopefully order new panel with cat flap built in without affecting folding
ruffage
I think a hole in the wall would be easier and cheaper. You could carpet the tunnel through to dry their paws on entry. No back door?
mr starface
No back door as will havw the bifolds so only place for hole would be side of the house .... Will speak to the builders and see what they say
MrFraggle
Also just occurred to me we are getting integrated blinds in our bifolds which will complicate things further probably
I would say you have pretty much ruled out a cat flap in the door in that case. Through a wall is a possibility though.
BB3Lions
Might end up looking like this?
mr starface
We had 2 cats but lost one last year:(
Almost 100% certain on wall solution now, seems only one available. At least I can waste more money on a smart catflapo_O
MrFraggle
mikeysthoughts
I got one of these as my Millie is a big beast, The SureFlap Microchip Pet Door for large cats & small dogs I ended up dismantling it and adding rubber grommets to the hinge as it was bloody noisy on opening and closing.
If you go through the wall you will need to line the tunnel as it will be deeper than a door. Something like this https://www.amazon.co.uk/SureFlap-Microchip-Tunnel-Extender-White/dp/B003HK9IIK
+1 for the sureflap, although I don't have the noise issue with ours.
Tempest
I hope you will take advantage and make the most of the design with some flair:
Robbowal
don't get these old codgers to do the install they left my place in a right state
just look at the mess of that hole
i mean you could literally fit a person through there;);)
IronGiant
The spanner in the works is they wanted integral blinds in the panes of glass.
Robbowal
then the only option is to have a panel to fit the flap in at the bottom of one of the door panes. possibly nearest the corner.
that way you can have the integral blinds and a safe cat flap.
