CAT 6 PROBLEM
Discussion in 'Cables & Switches' started by antlaff, Feb 7, 2014.
  1. antlaff
    antlaff
    Jun 23, 2008
    46
    Portrush
    I have been using Neet HDMI/Cat 6 baluns to send picture from the sky box to the TV downstairs. All worked perfectly for 7 months than this. What would have caused the below and can it be sorted easily?
    [​IMG]
    cat 6
    by Antlaff, on Flickr
  2. Philip4242
    Philip4242
    Jan 15, 2008
    1,021
    UK
    +167
    Looks like corrosion caused by a liquid to me.
    Might water (or other liquid) have dripped onto (or been spilled) on the plug or box ?
    Have you checked the corresponding socket, as there's little point in simply re-terminating the cable, if the socket (or the internal connections to the baluns themselves) is also affected !
  3. Trollslayer
    Trollslayer
    Feb 11, 2007
    25,990
    Poole
    +10,856
    Yep, liquid based corrosion here too.
