cat 5
Discussion in 'Cables & Switches' started by tahirti3, Jul 17, 2005.
  1. tahirti3
    tahirti3
    Sep 18, 2002
    1,388
    38
    anyone know if it would be ok to run 1 length of cat 5 over 20metres and then connect to a speaker by dividing the cores into two lots of 4?
    it would be for low level background music from a ceiling speaker.
  2. Moosh
    Moosh
    Sep 12, 2004
    1,999
    2
    Bristol
    +470
    That is fine.
    The only time distance becomes a real issue with CAT5 is networking. 10BASE-T allows segments of 100 metres (someone correct me if I'm wrong please as it's been a while since I did my CCNA training :)) before you need a repeater/switch/router to boost the signal.
  3. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    Indeed you are correct :thumbsup:
  4. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    You are correct in the distance/repeater.
    However, you aren't going to have much of a surface area of copper. Better to use 2 runs. One per channel. Some will argue that this isn't enough but for a small ceiling speaker it should work well.
