cat 5
Discussion in 'Cables & Switches' started by sfrost, Feb 11, 2005.
  1. sfrost
    sfrost
    hi guys,
    im new to this forum so be gentle.
    just starting on the home cinema thing having purchased a sanyo z3 projector (really very very good for the price)
    im now looking to run permament cabling. i would really dont want multiple cables trailing all over the place. is there a multi core cable that will do the job ( I DONT MIND MAKING ONE UP). i need component x2 , video x 1 .
    or
    can i make individual cables up out of cat 5.
    cheers guys
    simon
  2. BestGear
    BestGear
    Oct 22, 2003
    1,265
    +49
    Hi - and welcome to the forum!
    The CAT5 you have will not really do for cabling to the projector, other than for a serial cable if you wish to play with PC control (and possibly flash the firmware) of the Z3...
    You can use CAT5 for speaker cable if you wish - there are many threads covering that.
    There are many suppliers fo cheap, good quality cables - I would make sure you dont get hooked by the glitz and "flat earth brigade" sales techniques - once you reach a certain quality of cable, its a law of diminishing returns - you may not see/hear any difference with your kit.
    You can buy good quality cable from Maplin and terminate them yourself if you wish - there is an excellent "Shark" silvery white jacketed video cable they do - excellent with audio too...
    To be honest, there are a few other suppliers, such as CPC who will do you excellent cables for next to nothing... I would buy from CPC and save the swearing and burnt fingers...
    David
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Try electronic shops (those where you buy components like resistors etc.), they should have such cables.
