CAT 5 Speaker Cabling
sneaky
Im going to give this CAT 5 Milarky a go but I am a little confused by some of the posts.
I have castle compact speakers(not bi-wirable).
1) Is it best to use 2 lengths of cable for each speaker.
2) How many pairs do I use for each terminal.
3) Do I need to strip of the grey outer sheath of the CAT 5.
Chris
Stereo Steve
I would use 3 cables per speaker. Braid them together, strip the outer jacket off and then use all the solid colours for + and all the white-and-clolour cables for '-' .
THat way you will have 12 conductors for each terminal.Keeps it nice and simple and is difficult to get wrong. There are various threads on this forum about it.
I have only gone the bi-wire route because my speakers are bi-wirable and I felt this option was better than the jumper strips I had before.
Interested to hear your views once you have tried it. I was totally sceptical.
buns
I use a double braid. So I braid 3 parallel pairs together.
Alternatively you can go totally overkill..... separate down to individual conductors and braid 3 together. Then braid 3 of these 3's. Then 3 of them, then 3 again..... so 81 pairs per cable. Dont expect to have much skin left on your hands when you are done.
ad
sneaky
Cheers Fellas,
Why do you braid them together.
Say you are using 2 cables instead of 3.
Why not use one of the cables for the + and one for the -.
Chris
Stereo Steve
Twisting haleps with something or other, I'm not a techie. I suppose you could use a cable for each, or two for each.
No hard and fast rules, experiment and see what happens. I have not yet built the full spec cable, just got some old PVC Cat5 from the shed twisted together to try it. I was so impressed I'm in the process of getting hold of the proper stuff from Maplin to make up some proper terminated cables.
buns
Have a look for Nic Rhodes old posts on his matter..... There are all sort of electrical effects that could be mentioned, but Nic has been through them all already so i wont repeat
ad
65-inch LG C1 Review coming soon to AVForums
