Cat 5 long VGA cable - resolutions?
Discussion in 'Cables & Switches' started by goldfish1977, Sep 17, 2005.
  1. goldfish1977
    goldfish1977
    Apr 14, 2005
    14
    I just soldered a CAT5 8 m long VGA cable. Plugged the cable between my projector (Sanyo PLV Z3) and my graphics card (Radeon 9800 Pro) in my computer.
    Then I enabled the secondary monitor.
    Now I get a picture on the screen, but it's a little bit crippled. If I try to move a window to the "secondary monitor" (that is the projector screen) the picture gets really weird. As if the resolution or something would not be right.
    Does anyone know what resolution and frequency setting I should try with in Powerstrip, or what the cause to the above mentioned problems?
  2. Member 34135
    Member 34135
    CAT5 is not designed for VGA that might be part of the problem, why not use a proper VGA cable with 75 ohm coaxial conductors.
    Andy.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    The only way to use cat 5 with RGBHV is to use baluns, unless you believe thecable makes no difference brigade
