Cat 5 for audio and video distribution
Discussion in 'Desktop & Laptop Computers Forum' started by Ridcully, May 18, 2003.
  1. Ridcully
    Ridcully
    Feb 16, 2002
    355
    28
    +35
    This may seem like a really stupid question but are there convertors or any other way of sending audio and video down cat 5 cables.
    Ie
    a cat5 to digi coax or optical converter and vice versa
    and
    cat5 to video (such as DVI or possibly component / RGB) and vice versa
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Search for Kat5 its a cat5 AV distribution system. Should be some threads on it around.
  3. Ridcully
    Ridcully
    Feb 16, 2002
    355
    28
    +35
    Thanks for that. Both the Kat5 and iphomenet look very interesting but from what I can understand they are analog only ie s-video and stereo rather than DVI and 6 channel audio. Still have e mailed Keith at KAT5 to enquire
  4. Mike Dickeson
    Mike Dickeson
    Iphomenet uses the 4 pairs in cat5 to convey Composite video, Stero audio and IR control using electronic components. This obviously provides a cheaper solution for general distribution and control of AV & CCTV around the home. Dedicated standalone component, RGB 5.1 - 6 audio equipment etc. can be used in specified areas using ip as a additional source.
  5. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    hi Ridcully
    Keith is (was?) able to do custom units, including RGB.
    Of course you could always go for the super high tech approach of streaming your video as data to your client devices which then output in whatever format is appropriate (DVI, RGB etc)
    cheers
